I know rev 4 & 5 are supposed to be fine, but I'm having problems with the record case updating when I load new music.
When I add new songs to my hard drive, I then go into VDJ, add files to record case, and recurse...
The new music will not show up In VDJ until I physically navigate to the actual folder where the files live in explorer, refresh, then re-open VDJ...
I know two other people here have had the same problem this weekend...
It's pretty annoying...
anyone else?
Thanks!
anyone else?
Thanks!
geposted Mon 29 Oct 07 @ 8:21 am
Yes, I have exactly the same problem. I have reported this bug yesterday here:
https://virtualdj.com/forums/79502/PC_Version_Technical_Support/New_browser_bug__(video_included).html
geposted Mon 29 Oct 07 @ 12:49 pm
Same prob here... i thought i must have been doing something wrong.
geposted Mon 29 Oct 07 @ 1:17 pm
Vista or XP?
geposted Mon 29 Oct 07 @ 9:22 pm
xp and vista...... doesn't matter...
geposted Mon 29 Oct 07 @ 9:40 pm
Try right click on folder> add to database.
geposted Mon 29 Oct 07 @ 9:41 pm
Let me see if I have this correct. You are ripping tracks to a folder. You open VDJ, and those tracks don't show up, but the other tracks in that same folder, do show up?
geposted Mon 29 Oct 07 @ 10:01 pm
Or when you analyze the new music while the new files are highlighted... Add to DB and they should appeare with the rest of current song is folder.
geposted Mon 29 Oct 07 @ 10:15 pm
What happens if you choose add automatically in browser settings?
Seems like browsing to a filter folder (makes a database search) adds it back.
And it will of course show regardless if its added to search or not, if you go to the folder where the file actually is located
geposted Mon 29 Oct 07 @ 10:19 pm
Look here for a Fix
https://virtualdj.com/blog/DJ%20Cyder/
geposted Tue 30 Oct 07 @ 2:51 am
I guess that's why I am not having this problem. Hope this helps those that do.
geposted Tue 30 Oct 07 @ 9:28 am
DJ Cyder wrote :
Also - Please see page 16 of the User Guide -- installed in the My Documents -> VirtualDJ folder
"Searching in VirtualDJ is versatile and variable. What is meant by that? Just to the right of the search box there is a “search fields” selection button. Click on the bull’s eye circle and a list of 10 searchable fields is presented.
Depending on what fields are selected the search results will very. To ensure maximum results for all searches, select all the fields and the maximum search capabilities are available all the time."
geposted Tue 30 Oct 07 @ 1:51 pm
i know what you mean. i just re-checked this with rev.5 and it worked fine withouth having physically to navigate to the new folder or music, by just doing "add to search db". i couldn't do this in earlier revs.
and i didnt do any fixes to do this right either, just installed rev.5 over rev.4.
geposted Tue 30 Oct 07 @ 9:07 pm
