I have turntables and everytihg works good wth time code. However recently I bought a cdj200 I want to use it for time code purposes. There is only one line nput in the back of the bcd so it must g oin there. I setup everything in the time code config and have the one deck of cd time code on the right hand input. I get 100 percent signal but I have to pick two tcime code options even though I only have one.
I know I can control vdjs two decks with one turntable with the bcd but can the one cdj control two decks in vdj via the bcd soundcard. I hope you uderstand and thanks for any help.
If you need to know more info just ask
geposted Mon 29 Oct 07 @ 8:36 pm
solved:)
geposted Mon 29 Oct 07 @ 11:35 pm
Edit: Not solved:( I relaised when I done this I was now not able to cue. I used asio 4all and it doesnt give me the correct number of inputs.I remebr in a previous vrsion that one could use one cd player and switch back and forth between the vdj decks. Now I cant. Any help please?
geposted Tue 30 Oct 07 @ 6:36 am
