since virtual dj 4, the sampler records the sound before equalization. This was much better in virtualdj3 when you could sample just the bass of a track or mids or whatever custom equalization.
Magic loop button : by pressing one single button, the track is looped and played in sampler while the deck is set free.
so you can have your loop play with another track while you put a third track.
now this can be done by sampling loop then play it then put track volume down while you put sampler volume up.
it's a bit difficult to do perfectly so one button for that would be really cool.
or another way you could make it is make a button that you press once the track is looped and the button would send the loop to the sampler and free the deck at the same time.
geposted Wed 31 Oct 07 @ 10:03 pm
