effects on samples just like on tracks
geposted Wed 31 Oct 07 @ 10:08 pm
genious idea
and the ability to have more samples loaded
geposted Mon 05 Nov 07 @ 2:11 am
you can already do this .. if your using pro all your going to do is load the sample to the turn table and then place the effect to the turn table then record the quick sample then save it to file... now reload it as a sample and save and name it , you can have unlimited samples but it will take some work...
geposted Sat 17 Nov 07 @ 5:12 pm
