does anyone know if this works good with virtualDJ?
it comes with a program called torq but i hate that program....
anyone use this device it was $650 and i want to know if it was a waste or not.
thank you
bayatibaby =)
thank you
bayatibaby =)
geposted Thu 01 Nov 07 @ 2:55 am
yes it is a very good controler it is natively supported in the latest copy of pro
http://www.virtualdj.com/purchase/
the only thing we are waiting for in the next update is for the volume lights and progress lights to be supported
which they are waiting for info from m-audio which wont take to long :)
hope to see you with us soon
geposted Thu 01 Nov 07 @ 9:20 am
There's some more information here too:
http://www.virtualdj.com/forums/77360/Hardware_Technical_Support/Xponent.html
geposted Thu 01 Nov 07 @ 12:41 pm
