So I think I'm sold on VDJ. It's time for me to go digital and I have been looking into these DJ softwares from a far. Seem as if everyone around here is into the serrato system, although I'm not completely into the idea of having no control over the hardware it comes bundled with. I come from the music production side of things, and I use a RME hardware for all of my digital audio work. RME's hammerfall line has never let me down, prior to using RME I had a ECHO Layla, and that gave me nothing but problems.
I'm thinking of going big with my setup, if I'm going to invest it it, then I want the best hardware. Has anyone used RME's new RPM hardware?
This is what I want to use with VDJ, along with the pioneer DJM-800. Anything I should know about using the DJM to control the midi mixer inside VDJ?
How does VDJ's stability compare to serrato? I know a couple of people the had to deal with serrato crashing during a shows, and it was not pretty. I cannot afford to have to deal with this.
The computer setup that will be running my VDJ would be:
DESKTOP Intel 2.4G Core 2 Quad w/ 4GB RAM
Dual BFG GeForce 8800 GTS OC2 / 640MB GDDR3 in SLI configuration
RME Hammerfall PCI-e interface
RME Hammerfall RPM
Windows XP professional
These are pretty much the last things on my mind before I purchase the software and TCV's. Does this seem to be a pretty reliable setup to run VDJ?
Thanks for your help,
Jay
RME Hammerfall RPM
Jay
geposted Fri 02 Nov 07 @ 6:07 am
Those specs seem over kill for doing video, however if you have the cash to burn than go for it. I am running 2gm memeory 2.4ghz duo core 2 and 7950gt pcie card and no issues. I also use an exler nuo4 (great for midi) waiting for the evo5. I have heard of others using the 800 with no problems. So you should be all set.
geposted Fri 02 Nov 07 @ 8:05 am
Save your money.
I have one 7800gtx, Delta 44 sound, and DAC-3.
Jose
Jose
geposted Fri 02 Nov 07 @ 9:30 pm
