Hey guys I recently bought the maya 44 and I have one cdj200. My question is can I control vdj two virtual decks using only one cdj?. I have everything setup correctly I remebr this used to be an old feature. So anyways I have my cdj pluged into the maya anolog input 1 and 2. When I select one time code in the conguration settings I get 100%.
Now I can control deck 1. When I want to switch to deck 2 I enable time code on it It however picks up no signal becuase I think its trying to get a signal from inputs 3 and 4 on the maya.
However If I choose two timecode s I can work around this. I out my cdj into input 1 and 2 and play first deck. Take off thime code on deck one. Put on timecode in deck 2. Now I have to take out my cdj from input 1 & 2 and put it in 3 & 4 and everything works for decks 2...and so on.
However I don't want to have to do this everytime. Is there a work around so you can have the cdj pluged into inputs 1 & 2 and be able to control both decks.
You can do this in djdecks by selecting both inputs the same.
Thanks for a reply
Thanks for a reply
geposted Fri 02 Nov 07 @ 5:10 pm
Yes you can ;) you need to select ONE TIMECODE input in soundcard settings in VDJ though
And ALWAYS have timecode ACTIVATED when you mix. Meaning you must enable on deck 2 , BEFORE you turn off for deck 1, and visa versa.
Most skins have buttons for that in skin
geposted Sat 03 Nov 07 @ 7:11 pm
yeah I figured it outa after I posted...typical lol
geposted Sat 03 Nov 07 @ 7:24 pm
good to hear;)
geposted Sat 03 Nov 07 @ 7:39 pm
