Hi , im noticing sound of the song playback going up and down on virtual dj , kinda like little dips in sound occationally.It is very bad and I have got a gig to do tommorow so I need some urgent advice ???helpppppppppp.....
Everything has been good with the software , i did have to tweak my laptop before and it worked well for years. Last week i had to do factory reset and had to install V dj again ,and now everything is terrible . I have done all things on the PC Version Technical Support - Topic: "Skipping... Possible causes and solutions" WIN XP ,post and set all the vdj settings the the lowest quality and nothing has changed . Everything is updated on my laptop as well.
The specs of my laptop seem good ennough and I am using hercules mk2 controller , here are my specs , I am using Windows XP 1.73 GHz Intel Dual processor , 1 gig RAM , 80 gig hard drive and 160 gig external hard drive
Thanks Adam
Thanks Adam
geposted Fri 02 Nov 07 @ 10:00 pm
Please don't make multiple posts -
http://www.virtualdj.com/forums/79833/PC_Version_Technical_Support/Sound_levels_are_going_up_and_down.html
geposted Fri 02 Nov 07 @ 10:04 pm
