I'm at the club trying to hook up my TCCD's... the dual deck are working but VDJ is dragging the song ( slured ), it's barely moving... I don't know how to get it normal... please help!
geposted Sun 04 Nov 07 @ 1:15 am
which sound card do you have?
geposted Sun 04 Nov 07 @ 1:17 am
sorry, MK2 set at sky's guide for TCV
geposted Sun 04 Nov 07 @ 1:19 am
try performances to fastest n set latency to auto.... untick both safe mode n overclock...
N by any chance have u try auto config in the timecode setting.. It sometime need a couple of time before it get right n is the timecodes signal is 100 percent?
geposted Sun 04 Nov 07 @ 1:23 am
still nothing.. sometime my left deck move in reverse... the right signa is looks good in wave signal.. the left is somewhat good but not great signal. I did try to switch the tc disc around. The downloaded TC is for dual decks and not the high noise TC
geposted Sun 04 Nov 07 @ 1:35 am
what cd players are you useing?
geposted Sun 04 Nov 07 @ 1:36 am
tascam cd-x1500... As soon as I untick the TC button on skin everything works properly. 0% signal on both
geposted Sun 04 Nov 07 @ 1:40 am
these are an unusual set of cd players , you are using the consumer leveled tccd?
so to confirm you have let the latency in the mk2 control pannel
and set to auto latency in vdj?
could you take a screenshot of your timecoded signal?
geposted Sun 04 Nov 07 @ 1:45 am
i don't have a way to get it to the internet computer.. this the clubs computer i'm using to communicate. This also happend on my stantons 501 dual decks
geposted Sun 04 Nov 07 @ 1:56 am
ok if the wave is tiny tick ria preamp
if it is large outside the lines turn down the gain
some examples of how the wave should and shouldnt look are here
http://www.virtualdj.com/forums/76267/Hardware_Technical_Support/TCV_TCCD_Setup_Manual.html
did you set those latency settings?
geposted Sun 04 Nov 07 @ 2:01 am
Same still... Well, I gotta go home and get ready to play tonight 1 hour / half... I wont have time to practice. I'll chat with you about it tomarrow.
Thanks everyone for your attention. You guys are top class. Maybe I should go with my original idea of icdx's...
geposted Sun 04 Nov 07 @ 2:17 am
icdx would be a better option in my opinion
geposted Sun 04 Nov 07 @ 2:29 am
You could be in luck. Two for sale here.
geposted Sun 04 Nov 07 @ 2:49 am
question: Is it easier to setup TT's than CD for timecode?
geposted Mon 05 Nov 07 @ 8:23 pm
Actually the set up is about the same but with tccd i always get 100 percent signal but the tcv i always get 0 percent..hee,,that was on my stanton tcv but now i gonna try my VDJ TCV n see the differents:) Just there is no time for me to try it at the moment:(. And as to ur question, to my personal exprience, i would say tccd is much more easier to set up than tcv:)
geposted Mon 05 Nov 07 @ 8:37 pm
if you use icdx you dont have to bother its platter acts aslo as a midi controler
geposted Mon 05 Nov 07 @ 9:24 pm
Yes, I played with it before... Wait, that doesn't sound right. You know what I mean.
geposted Mon 05 Nov 07 @ 9:28 pm
Yes Fat...I think we all know what you mean. You might want to wash your hands before returning to work......
geposted Mon 05 Nov 07 @ 9:36 pm
He needs to shave those hairy palms.
geposted Mon 05 Nov 07 @ 9:40 pm
Now THAT made me laugh out loud at my desk....
I was more worried about him going blind.
geposted Mon 05 Nov 07 @ 9:44 pm
