Just downloaded Djcels Herc console mapper, to try and pin port a issue i've got. Just want to know when I next use my herc will vdj automatically use the mapper after I've chosen it in the remote control set up
Jimmy b
geposted Sun 04 Nov 07 @ 8:48 pm
you will need to activate it on Effects > external devices
it will hold all of your settings from the previous session
geposted Wed 07 Nov 07 @ 11:28 pm
On some machines it sometimes works ok but if not, just enter in Settings of VDJ and disable and enable MK2 again and the mapper will start to work. On my previous laptop (Gericom Hummer) I had to do it every time and now on HP 530 laptop it is working all the time as it should. Don't know what is the problem though :(
geposted Thu 08 Nov 07 @ 3:36 pm
I never got the mapper to work but will try skyfxl's advice later this evening...
geposted Fri 09 Nov 07 @ 2:15 pm
I've been trying now for a few day's but I can't get it to work either, followed sky's advice but nothing.
It's to hard for my simply brain, lol
Jimmy b
Jimmy b
geposted Fri 09 Nov 07 @ 2:24 pm
Hm, does anyone sees my post above? Try the way I described.
geposted Sat 10 Nov 07 @ 4:06 pm
