Instructions on timecode bypass option needed urgently for rev 5 Please......
geposted Mon 05 Nov 07 @ 1:47 am
The inbuilt bypass. Go to option. Keyboard shortcuts. UNder the turntable section I think there shouold be a bypass option and just select which deck to bypass..etc
geposted Mon 05 Nov 07 @ 2:54 am
have they added this back in? it was taken out in either 3.x or 4.x for no good reason. i find it useful to troubleshoot TCV, if there is a problem. the sound will be less than perfect tho
geposted Tue 06 Nov 07 @ 2:15 am
yes its back an much improved, you can now use the software eq's on regular vinyl. Give it a try.
geposted Tue 06 Nov 07 @ 6:26 am
I set it up like cstoll says on the manual and it now appears on the shortcuts but I still can't get any sound out. I have active deck activated and am using the herc 2 as the asio soundcard in this particular set up......Is there anything else I need to tinker with?
geposted Tue 06 Nov 07 @ 6:38 pm
