The full reverse plug in contains a bug.
If you have a song in a loop in deck A ready to mix (for example) and you use the full reverse effect on deck B, it will release deck A from the loop!
geposted Mon 08 Nov 04 @ 2:12 am
ok, I will try to have a look at this.
This plugin was made for VDJ 1.X, I may have some little change to do to correct this :p
geposted Mon 08 Nov 04 @ 8:04 am
from what i've seen with this plugin it just completly unloads the song on the deck that it is activated on...
geposted Mon 08 Nov 04 @ 8:06 am
