I mostly mix hip hop hop. I do a lot of remixing using the sampler and also fl studio. Even after analyzing the song's BPM's, and when I que up an incoming song, and hit the sync, and start up the incoming song on the downbeat it always goes off beat. which is a pain cause I always have to make adjustments to my mix when I am trying to add effects, and or samples to my mix. When I right click the sync it will throw it way off beat. Am I doing something wrong? I just want the miix to stay aligned where I can just set and forget. I do a lot of adding instrumentels to song's where I need the beats to stay aligned. What's the best way. Oh ya, I do know how to beatmath, I just need the sync to work better so I can spend more tiime on doing other things, Thanks.
geposted Tue 06 Nov 07 @ 3:22 am
Davey, you need to also adjust the cbg positions. The beatlock uses the info to lock the beats. Check out my post in Mixing lessons section, it should give you an idea of what i'm talkin bout.
geposted Tue 06 Nov 07 @ 4:03 pm
