Will Rane's TTM 56 Mixer work with virtual dj?
geposted Fri 09 Nov 07 @ 1:26 am
I'm not sure I undestand the question, but any dj mixer will work with VDJ. Also, if the Rane is midi compatiable it opens up a whole different level of flexibilty and creativity. But once again any DJ mixer will work with VDJ
geposted Fri 09 Nov 07 @ 1:46 am
The TTM56 is a regular mixer just like any other mixer. It should work. Maybe you're referring to the TTM57 and I don't think it works with VDJ.
geposted Fri 09 Nov 07 @ 4:50 pm
The TTM57 will work as well, because VDJ supports has ASIO drivers for the Searto soundcard
geposted Fri 09 Nov 07 @ 6:29 pm
If the ttm57 works with VDJ then someone please tell me how to configure asio to work with Time Coded Vinyl.
geposted Wed 19 Dec 07 @ 3:39 pm
The 57 will not work to control time code. i have the 57 and am forced to use another soundcard when using vdj.
do a search and you will see the issues with the ttm57
geposted Wed 19 Dec 07 @ 7:20 pm
