Ok guys, I've had several people tell me we can search by BPM...
How? It just doesn't seem to work for me...
let's say I'm mixing a nice 117.something set, and I draw a blank... I'm wondering what else I could throw in there to do something I don't play every damn night...
How can i search for a range, say 115-120?
or just all of the 117.xx range?
is this even possible?
I can't seem to make it happen...
Thanks in advance gents!
geposted Fri 09 Nov 07 @ 8:04 am
hi steve
dont know if you have done this bit yet but near the search bar there looks like two bullseyes, chose the one on the left and open it and select files you want to search by and it should be good to go...
Tayla
Tayla
geposted Fri 09 Nov 07 @ 8:42 am
geposted Fri 09 Nov 07 @ 2:24 pm
I did that.....
yes if I search for say... 120... all I get is 120...
and only a hand full...
how do I search a range?
geposted Fri 09 Nov 07 @ 5:47 pm
Try 120-125 ;-)
geposted Fri 09 Nov 07 @ 5:55 pm
Ludek wrote :
Try 120-125 ;-)
And make sure you have bpm included in search (tick the bpm option)
geposted Fri 09 Nov 07 @ 6:30 pm
Tayla seems to have it right :]
geposted Sat 10 Nov 07 @ 4:59 am
you can also try to rearrange your your music list based on the bpm list
what you have to do is, in the folderview, on top of your music list, just click on the bpm button.
and then just scroll down to the range your looking for and there you go.
thats what i do
thats what i do
geposted Sun 11 Nov 07 @ 5:56 pm
