I just downloaded VDJ ver 5 rev 5, as well as the Hercules MK2 update. Are these full installs right over my original (ver 5 rev 2)? Or do we need to uninstall all and reinstall?
geposted Fri 09 Nov 07 @ 7:11 pm
Rev 5 can't be installed over, or full install. I am not familiar with the Herc. Try either way, what's the worst that can happen? Well, your machine could explode into a ball of flames, but if you get it on film, you could put it on youtube.
geposted Fri 09 Nov 07 @ 10:24 pm
In your download center you should have two versions of MK2... update and a full. You can run the update over the current. or deinstall the current version and run the full intall
geposted Fri 09 Nov 07 @ 10:38 pm
v5.05 can be installed on top
the mk2 software on this site is home editon you dont want this
you perhaps want the drivers from the hercules site
geposted Fri 09 Nov 07 @ 11:04 pm
could't he just update the drivers using the downloaded disc. Like for me, I keep a current approved copy of all the VDJ/Cue disc and MK2 disc in my bag at all times just in case I need to reload the system. Which I had to do once last month before work..
geposted Fri 09 Nov 07 @ 11:26 pm
OK thanks guys. I'll install VDJ 5.05 over my existing, and check out the Herc site for updates to what I already have.
geposted Sat 10 Nov 07 @ 2:55 am
and of course , keep that fire extinguisher and camera , handy
geposted Sat 10 Nov 07 @ 11:30 pm
