So I picked up another 160gig WD passport today that I am dumping the platinum series on as well as anything else I need to pull off a mobile gig.
I've been using VDJ 4.3r12 and 5.0r5 for strictly club use.
My external i've been using for club has been drive F. My favorite "music" folder points to it.
Will I mess up my 4.3r12 database by having the other external in?
Sure there might be times when I have both plugged up at once but I'm sure that would be a rare chance. My concern is, since mobile gigs fewer than club gigs, I don't want to risk messing up my databases for my F drive.
How can I use my other external without any goofs?
Thanks!
Thanks!
geposted Fri 09 Nov 07 @ 11:27 pm
no it should be ok as that drive will tend to keep the drive letter F
if it looses this
simply change the drive name back to F using this little guide from ms
http://support.microsoft.com/kb/307844
hope that helps :))
if it looses this
hope that helps :))
geposted Sat 10 Nov 07 @ 12:29 am
