Hello,
i activated a clipbank it works perfect, after a while i tried to stop it. It wasn't possible only thing what stops it was to go to config and deactivate the video at all. After I activeted it again the clipbank loop was still working, anybody any idea.
my pc:
XP
AMD Athlon X2 5800+
3072 Ram
Controller: Numark DMC 2
Grafikkarte: HD 2900XT 1024 MB-DDR4
Soundkarte: M-Audio Delta 1010 LT
my pc:
XP
AMD Athlon X2 5800+
3072 Ram
geposted Sat 10 Nov 07 @ 9:13 am
anyone any idea to fix it. or has anybody else this problem
geposted Mon 19 Nov 07 @ 6:09 am
any idea
geposted Fri 30 Nov 07 @ 12:38 am
try running it without your controller first, if problem persists you could try a re-install of clipbank see if that helps, make sure you clean out old clipbank dll first...
Tayla
Tayla
geposted Fri 30 Nov 07 @ 5:13 am
From memory theres a new version of the clipbank in the downloads section, are you using that version?
geposted Sat 01 Dec 07 @ 6:31 am
