i got a Blue Snowball , usb mic .....
it's not really plug 'n play .........when i installed it the system immediately found it , but there was no volume , i rebooted , no joy
everything is working and set right in sounds and audio properties , but no sound ........
i clicked on the voice tab and ran the hardware testing wizard .....when you are prompted to speak it has an input when you click next it has an output and it finally works ???????
only problem the latency is way too high ????
i tried to update the driver for the system sound card , i guess it updated but it didn't fix the problem ......
is there a way to adjust the latency on the system sound card ?? Conexant Amc ?? or can i run it into my Presonus Firebox soundcard ??
also in VMix 5.2 skin the mic fader didn't work ??
i can't get any support from them , they only have phone support M-F bankers hours and then email .....there forum takes 24 - 48 hours to post new items ........
my operating system is XP media center edition .....
geposted Sat 10 Nov 07 @ 4:19 pm
i have a slight solution.
1. start > run > "msconfig" > services > "hide all microsoft services" > disable all
2. start > run > "msconfig" > startup > disable all
this should help latency issues.
but seriously bro, connect your mic to the mixer and be done with it.
$10 mix + 5$ cabel = $15 solution.
DJ Shahar
www.djshahar.com
DJ Shahar
www.djshahar.com
geposted Sun 11 Nov 07 @ 3:32 am
thanks i tried uninstalling the usb ports and then rebooting ...no fix there , also i updated my BIOS again no luck .....
i hate to quit but i'm running out of options ......
i would like to use this mic ,Blue's reputation for mics is very good , it's very sensitive , like me , and it looks space-age bachelor pad ......
geposted Sun 11 Nov 07 @ 12:36 pm
