Hello everybody its TheTurk here watsup up?
I am still djing! but one day when i was playing around with my decks and mixer i realized that when i move the crossfader all the way to the left it didnt cut out the right deck music! then i tried playing with the CF SLOPE and put it the opposite of what i had it at which was set up for scratch djs... then i noticed this time it fades out... but i still had to play around with it a bit to make it cut out the right deck when i want to use for scratching ... i got it to work but it still doesnt work perfect because the noise still comes from the right deck when i have the crossfader all the way to the left, the noise from the right deck still comes in a little bit... but not too noticeable but still no good
anyways i put my nose near the crossfader to smell the inside a little bit and it smelled like it was burnt or fried or something.... it still works fine! and no smoke comes out but the inside smells burnt! i dont know why? should i get it checked out?
and the funny thing is when i put the crossfader all the way to the right to cut the left deck, it cuts out the music perfectly ! but i dont scratch as good with my left hand as i do with my right one....so the only problem is cutting out the right deck's music
And yes the volume controls all work and so do the gain and master and eqs only the crossfader sometimes doesnt cut out the right deck fully when i fade out to the left
and the type of mixer i am using is a Numark DXM03 and i bought it new from tom lee sometime last year
geposted Sun 11 Nov 07 @ 11:40 pm
Do you have kill switches?? I had the Numark DXM09, and I can say that I will never buy another Numark Mixer! I had the same issue, it seems that it was a kill switch that wasnt making correct contact.
geposted Sun 11 Nov 07 @ 11:56 pm
sounds like its really dirty...try cleaning it...had a burnt smell in one of my mixers and that was the problem...also dirt can cause faders ect..not to work properly...;)
geposted Mon 12 Nov 07 @ 1:08 am
what mixer is it. it may be able to replace the cross fader usally there user replaceable. better that bying a new mixer
geposted Mon 12 Nov 07 @ 1:33 am
Perhaps i should try cleaning it then.... and minedoesnt have a kill switch anywhere...
thanks for the help!
geposted Mon 12 Nov 07 @ 2:28 am
oH yeah its a Numark DXM03 and the crossfader is replaceable but im wondering if the crossfader is causing the problem or is something causing the problem?
geposted Mon 12 Nov 07 @ 3:17 am
