Hi there, I dont own Virtual dj right now, i have been using traktor for the last wee while. I have been messing about on my friends computer and i'm intrigued. I own a bcd3000 controller. My main questions are... can i use virtual dj with my controller? Im wanting to get some virtual vinyl would it be possible to use time coded vinyl through my bcd3000 using virtual dj? With a set of decks, Time coded vinyl (serrato for instance) the bcd3000 and virtual dj would i be able to use the vinyl properly, would i need anything else. I understand that is alot of questions but any help would be greatly appreciated, im basically trying to get the cheapest most reliable way of controlling mp3s while keeping the tactile feel of records. Cheers.
geposted Tue 13 Nov 07 @ 11:31 pm
Your best solution then is to get a dedicated sound card and simply use the BCD3000 as a controller. There have been well documented issues with the BCD2000 model and some here have gotten the BCD3000 to work. However; for the best LATENCY possible, I would consider a dedicated sound card like the MAYA44 USB or U46DJ, or since you are still in need of the software and vinyl - get Numark's VirtualVinyl it is VirtualDJ with a sound card and the vinyl in one package.
geposted Wed 14 Nov 07 @ 12:08 pm
