Am I right in assuming the vst effects support is gone in the latest version?
hope it comes back one day if thats the case?
geposted Sun 18 Nov 07 @ 1:33 am
my bad the folders just moved :P
seems to work well in V5, only request would be to have the ability to choose the level the effects for a deck can be on:
so for example if you wanted to be able to scratch with a delay and you wanted the delay to keep going if the cross fader wasn't on that deck any more and keep going even if the deck stops moving if you know what I mean. at the moment deck stops plug in stops.
at the moment im trying out the res filter built into the TC Konnekt live interface so it handles the computations of the taking the load off VDJ, so far so good.
geposted Sun 18 Nov 07 @ 2:17 am
what I mean is if the effects acted more like sends...ya dig
geposted Sun 18 Nov 07 @ 1:38 pm
