Is there a way to ad a video clip to the clip bank with transparancy? I'd like to have my logo spin in over the currently playing video.
Thanks,
Greg
Thanks,
Greg
geposted Mon 19 Nov 07 @ 9:42 pm
you can get your logo on screen using the logo plugin unfortunately no spin
geposted Mon 19 Nov 07 @ 9:49 pm
I'm not sure, but if you do it with a blue or green background, can't you use a Chromiumkey or Lumakey effect?
geposted Mon 19 Nov 07 @ 9:50 pm
Chromakey is what I'm looking for. I'll try that. Thanks!!
Greg
Greg
geposted Tue 20 Nov 07 @ 2:21 am
Can't seem to find a chroma key plug in. Does anyone know that it exists?
Greg
Greg
geposted Tue 20 Nov 07 @ 4:16 am
Check here. Look over the whole page, to see what you can find.
geposted Tue 20 Nov 07 @ 7:26 am
I asked about this a long time ago and it was a flat no
but id love to know if the situation has advanced at all ?
would be perfect for scratching video animations that had their background as transparent!
this would also set VDJ apart from dvdj's and others
geposted Tue 20 Nov 07 @ 12:59 pm
