Hello there folks...:o)
I've been DJ'ing for about a year now and am looking to buy VDJ. However, I'm a bit concerned about it's...stability. Functionality wise, i think it's great, but i was a bit worried when my system started using (and running out of) virtual memory.
I've therefore built myself a system with 2 things on it - a massive (well, 3590 tracks) music library and another trial version of VDJ.
I've had no problems yet, but check this. The system's not great, but as far as i can see it's doing the job (touch wood). I'm running with 512mb ram and a measley processor, i know - Athlon 600Mhz. I've stuck a soundcard in there too for added functionality and like i say, so far, i've had no problems.
Got a night to do on saturday and am thinking of using this system then. Any comments/advice, anyone???
As you can see, i'm only an amateur just now, but VDJ is (so far) a wonderful program. Is there success in the pipes for me and VDJ???
Any comments would be greatly appreciated...:o)
Cheers
Chris
Cheers
Chris
geposted Thu 11 Nov 04 @ 5:53 pm
Well chris all you need is to cough up the dough for vdj and you will be able to mix 512 ram is excellent!
Hope to see your status change soon!
Regards Andre
Regards Andre
geposted Fri 12 Nov 04 @ 12:16 am
I think that Athlon 600Mhz is not enought ...
geposted Fri 12 Nov 04 @ 1:41 am
What would you recommend Man-Tk???
Incidentally, i'm looking to upgrade my homebuilt anyway with a new motherboard and cpu...
Cheers...:o)
Cheers...:o)
geposted Fri 12 Nov 04 @ 2:02 am
I tried VDJ on a 566 mhz (with 512 ram) I found it to be very unstable and would have never trusted it in a live performance. I bought Atomix instead.
Since then I've upgraded my lap to a Pent 4 / 2.80 GHz and I bought VDJ, now I can run it with no problems and probably have enough system resources to cook some Jiffy Pop for my midnight snack. (Hey, it's all about the money! $$$)
geposted Fri 12 Nov 04 @ 2:25 am
Good choice djrenee VDJ's the best PCDJing software
geposted Mon 15 Nov 04 @ 8:52 am
athon xp 2800 (512 kb L2 memory cache)
with 512mb memory or 1 GB BETTER !!
Pentium 4 (with 1 mb L2 memory cache) PRESCOTT 2,8 is a very good option
Don't use processor of low range like Sempron ..Duron or Celeron ...
I recommend that you try to invest in a good machine ...Think about the cost of double cds
My System :
Pc Cube Shuttle
Athon xp 2800
512 mb memory (1024 it would be perfect)
2 X 160 GB hard disk
Ati Radeon 9600
PCI Audigy Ns
Maya 44 USB
LG dvd RW
VDJ with Time Code Vinyls
With this system I work everyday 8 hrs in a disco and haven't any problems since version 2.03 ...
My System :
Pc Cube Shuttle
Athon xp 2800
Ati Radeon 9600
PCI Audigy Ns
Maya 44 USB
LG dvd RW
geposted Mon 15 Nov 04 @ 10:19 am
