I'm using VDJ Rev5 and I'm inchworming my way to where I want to be.
First I rip the DVD's using the DVD Decrypter. (I had a few files come up with errors using the VDJ ripper when the DVD Decrypter worked OK.)
The files are going into an external hard drive and look like this "VTS_01_CHAPTER_40_1.VOB"
If I grab another DVD and rip itto the same folder there will be conflict because they have the same filename.
I go in and add the artist name and title within VDJ but that does not alter the filename.
I think what I should be doing is change the file name to a format that includes the artist and title and then that would carry over.
Please give mesome ideas on what has worked for you.
Thanks.
Thanks.
geposted Thu 22 Nov 07 @ 3:57 pm
Do you guys rip each DVD into its own folder and then utilize the virtual folders to see all them.
geposted Fri 23 Nov 07 @ 2:52 pm
I just go into the actual file and right click to properties and rename it there. Make sure you keep the .VOB
geposted Fri 23 Nov 07 @ 5:33 pm
