Hello all!
My friend recently bought Virtual DJ and I get in on it a few times as well.
We managed to set up a Shoutcast server but one thing that I saw is that the URL shows as virtualdj.com
Is that changeable?
I also saw there is fields for AIM, and similar things.
Can those be changed too?
Thanks in advance.
Is that changeable?
Thanks in advance.
geposted Fri 23 Nov 07 @ 8:55 pm
if you are streaming from virtual dj (as the server)
it is possible to change the stream adress in pro edition
geposted Fri 23 Nov 07 @ 9:49 pm
So, what version does your friend have?
geposted Fri 23 Nov 07 @ 9:52 pm
I would think he has the pro as he said "i got the best one"
geposted Mon 26 Nov 07 @ 4:50 am
Where is the option? If i go there and its not there then he doesnt have it.
geposted Mon 26 Nov 07 @ 5:05 am
