This is intended to be a bit of a poll, please post your computer specs and the stability you receive from Virtual DJ Pro (current release), if you don't experience full stability, please be brief with your problem.
This is a poll, not a problem solving thread, please don't hijack or get side tracked.
Thanks.
Thanks.
geposted Sat 24 Nov 07 @ 9:14 pm
Both used for Audio only purposes.
Laptop 1 (NEW)
Advent
Intel Centrino, Core 2 Duo, 1.77GHZ.
2 Gig of Ram.
120gb HD
Integrated Graphics card
Value when new (07): £500
Hercules Soundcard.
Stability (Version 5, Rev 5):
Very stable (even when multi-tasking) , no crashes or hangs, very smooth playback and great sound quality (runs perfectly at maximum quality settings). Used running 2 controllers and an external HD. Very impressive.
Performance rating: 5/5.
Laptop 2 (OLD)
Desktop procc, 2.6ghz Pentium.
512mb of Ram.
40gb HD
Integrated Graphics.
Value when New (03): £800
Hercules Soundcard.
Very stable and fairly smooth (when not multi-tasking and with reduced Sound quality settings), this was never too much of a problem as the sound was still rich, but the program felt like it wanted more from the system, just a bit.
Performance Rating: 3/5
Laptop 1 (NEW)
Advent
2 Gig of Ram.
120gb HD
Hercules Soundcard.
Laptop 2 (OLD)
512mb of Ram.
40gb HD
Hercules Soundcard.
geposted Sat 24 Nov 07 @ 9:26 pm
Amd 2800+
1.25Gig ram
80Gig hardrive
maya44 soundcard
Runs perfect. I can run several other programs at the same time and not get any soundglitches. Perefect:) Stability =:)
with bcd2000 it is also super stable except not so good for multitasking because because sound distrotion when minmising vdj but this is probably caused by the bcds soundcard. VDJ FTW!!
5/5
1.25Gig ram
80Gig hardrive
maya44 soundcard
5/5
geposted Sat 24 Nov 07 @ 9:54 pm
Intel Core 2 Duo T7500 (2.2GHz/800Mhz FSB/4MB cache)
256MB NVIDIA GeForce 8600M GT
2GB Shared Dual Channel DDR2 at 667MHz
160GB HD
MAYA 44 USB
It's a hit or miss for me, first time doing video mixing, no issue's. VDJ crashed once after that and it's been a challenge trying to figure out what's going on. Now it shut's down with no crash guard. 3/5 I would say.
160GB HD
MAYA 44 USB
geposted Sat 24 Nov 07 @ 10:07 pm
Specs:
P4 2.8 Ghz, Dual Core
2 gig RAM, 1.5 TB disc space (spanned over multiple drives)
Windows Vista
3 Monitors running NVidea GeForce FX5200
I never have any issues... however it should be noted that I'm a professional programmer, not DJ. I use this software for the fun of it, not pro work.
Hope this helps
James Rose
New York City
Windows Vista
Hope this helps
James Rose
New York City
geposted Sat 24 Nov 07 @ 10:19 pm
Specs:
ASUS M2NPV-VM AM2 NVIDIA GeForce 6150 Micro ATX AMD Motherboard
AMD Athlon 64 X2 6000+ Windsor 3.0GHz 2 x 1MB L2 Cache Socket AM2 Processor
2 Gb 800mhz Ram
ATI Radeon X1950 Pro Video
Windows Vista Home Premium
1 Tb SATA Videos and Music
300GB SATA OS and Programs
Don't have many issues, the ones I have are mainly some hang issues on the second output during Automix while the videos are transitioning and loading the new song. Other than that no DB issues or anything else so I rate it 4/5.
2 Gb 800mhz Ram
geposted Sat 24 Nov 07 @ 11:11 pm
Alienware Area 51-m9750
2.33 ghz centrino duo2
2048 mb ddr3 ram
2x512mb nvidia 7950GTX in SLI
2x 160gb 7200rpm WD SATA drives in Raid 0
Win XP SP2- slipstreamed for performance
VDJ 5.0 r5
Never crashed once on this laptop in 6 months.
Previous laptop
Acer Aspire 5500...
Crap specs
Crashed all the time...!
2048 mb ddr3 ram
VDJ 5.0 r5
Previous laptop
Acer Aspire 5500...
Crap specs
geposted Sun 25 Nov 07 @ 5:34 am
(Desktop) - Home Use
DIY
BenQ LCD Panel 17"
Creative Prodikeys
Creative Desktop Theater 5.1 DTT2200
Intel(R) 945/P PCI Express
Intel Pentium Duo Core 2.66Ghz, 2.66Ghz
XP Professional Version 2002 SP2
4gb Ram
Internal 400 gb
External *A 160 gb
External *B 500 gb
Nvidia Geforce 7300GS
(Laptop) - Gigs use
HP Pavillion dv5000 15.4"
Mobile Intel(R) 955XM/945GM/PM/GMS/940ML Express PCI Express
Intel Pentium Duo Core 1.66Ghz,1.66Ghz
XP Home Edition Version 2002 SP2
1gb Ram
Internal 80 gb
External *A 160gb
Nvidia Geforce 7400
(Laptop) - Gigs use
Macbook White 13.3"
Macbook 1,1
Intel Core Duo 1.83Ghz
Mac OSX Tiger 10.4.9
512 Ram
Internal 60gb
External *B 500gb
Intel GMA950
*Shared HDD
1 Creative Audigy 2ZS Platinum Pro
1 Behringer UCA2000
1 Hercules MK2
I use both the PC com only for audio n no video as the graphic is not up to the task n for the mac i generally use both audio n video n it werk good;) No serious crash for me for a long time now n i hope it stay this way ;)
Overall VDJ V5.05 : 4.5/5
Mac V5 (Public Beta 3) : 3/5
DIY
BenQ LCD Panel 17"
Creative Prodikeys
4gb Ram
Internal 400 gb
External *A 160 gb
External *B 500 gb
(Laptop) - Gigs use
1gb Ram
Internal 80 gb
External *A 160gb
Nvidia Geforce 7400
(Laptop) - Gigs use
Macbook White 13.3"
Macbook 1,1
512 Ram
Internal 60gb
External *B 500gb
Intel GMA950
*Shared HDD
1 Behringer UCA2000
1 Hercules MK2
geposted Sun 25 Nov 07 @ 6:09 am
I do Video Only
HP nw9440 mobile workstation laptop
Core2Duo 7200
2GB RAM
512MB NVIDIA Quadro 1500M Video (runs at Geforce 7800GT speeds)
250GB internal SATA drive
MK2 for sound
Windows XP (I refuse to use Vista for VDJ)
Overall runs rock solid considering I beat the crap out of it every night. I don't just use this for VDJ. While VDJ is running... I frequently browse the web, run outlook & excel. I can even DVD decrypt a DVD on the fly AND encode video using TMPGenc all while running VDJ. Hell I am making this post now while running a VDJ video automix. ;)
This laptop is an absolute beast now that I have all the glitches corrected and I would recommend it to anyone (laptop is a little pricey though - close to three grand).
Overall performance.... 5/5.
I would like to add a few more data points. I did have a couple of issues in the past with this laptop. I was getting an occasional bluescreen once a month which ended up to be the PCMCIA cellular card I was using. I changed aircard brands (which changed the drivers) and the bluescreens went away.
I also started getting some bad lockups and some hard disk errors. After replacing the hard disk which didn't solve the problem, I had HP come out and replace my system board because I figured there was an issue with the SATA disk controller. After they replaced the system board... problem solved.
So if you guys are having some issues with your setups... make sure you check out all your hardware and test your components individually.
It probably also helps that I also work fulltime running an IT department for a global advertising firm. So I have extensive technical knowledge and PC troubleshooting skills to keep this laptop in top shape. But it's still a great laptop nonetheless.... best laptop I have ever owned so far.
Core2Duo 7200
2GB RAM
MK2 for sound
geposted Sun 25 Nov 07 @ 7:14 am
I do Mixed Video / Slideshows and Visualizations.
Gig Machine:
ASUS M2NPV-VM
am2 socket
Athlon x2 3800+ cpu 2.00 Ghz duo-core
2 GB DDR@ 800mhz
Nivida 6150 GPU
Vista O/S
Sits in a rackcase, and I use a DMC2 with it.
Rock Solid performance.
Rating 5/5.
Home Machnine
Asus Mother board
Intel dual-core pentium cpu
2 GB DDR2 667 mhz
ati 2600 pro video card 512mb ddr2 vid memory.
XP O/S
Works very well with VDJ - some video green lines every so often Have updated Directx and video card drivers But still happens every now and then.
Suspect it might be due to the crappy intel pentuium dual core (gen1)
When I rebuild both systems - both will be quad-core AMD systems
4/5
Gig Machine:
ASUS M2NPV-VM
am2 socket
2 GB DDR@ 800mhz
Nivida 6150 GPU
Vista O/S
Rating 5/5.
Home Machnine
Asus Mother board
2 GB DDR2 667 mhz
XP O/S
4/5
geposted Sun 25 Nov 07 @ 9:53 am
Bought this as a gaming machine years ago and it still runs like lightning
AMD 300
2G RAM
Maya 44 Sound
Geoforce Graphics
Really stable for hours and hours of pure MP3 mixing, try to do anything fancy like loading a CD or mixing with Winamp feeds it freezes. Try mixing in a CD track that VDJ has never seen before from an MP3, you'll see what I mean.
Normal use: 10/10
Off plan use: 1/10
Off plan use is important when unexpected things get thrown in during a set when theres a floor full of people in front of you. The software needs to be bomb proof no matter what I get up to behind the scenes and I've just not found that t be the case here.
(( EDIT: But do you have a licence? ))
AMD 300
2G RAM
Maya 44 Sound
Geoforce Graphics
Normal use: 10/10
Off plan use: 1/10
geposted Sun 25 Nov 07 @ 1:26 pm
IBM Thinkpad G40
P IV 2.4
2GB DDR400
160GB 5400 ATA 100
Maya EX7 sound
Stability.
Not one crash or hang up with any revision of 5.X The only thing I notice, is on occassion when loading or playing a DRM.WMA file. The waveform is glitchy (jumpy), but the system plays on.
P IV 2.4
2GB DDR400
160GB 5400 ATA 100
Maya EX7 sound
Stability.
geposted Sun 25 Nov 07 @ 4:44 pm
Intel Core2Quad Q6600 G0
ATi X1950 Pro 512Mb
2Gb DDR2 RAM
M-Audio Xponent
Windows Vista
Creative X-Fi Platinum Pro as backup soundcard
PCDJ DAC-3 as backup controller
No problems at all with the main rig.
The X-Fi only really works in WDM - the ASIO mode causes VDJ to be very laggy (suspect driver issue). The DAC-3 works but causes VDJ to crash on exit. Since they are only backup devices I'm not bothered.
ATi X1950 Pro 512Mb
2Gb DDR2 RAM
M-Audio Xponent
Windows Vista
geposted Sun 25 Nov 07 @ 9:01 pm
I'm using a loaner laptop at the moment while my laptop is being fixed.
Don't know specs exactly but its something like
AMD Turion
2gb Ram
128mb dedicated ati graphics card
Windows home premium
Running 5.0rev5 and its running like a dream. On my hp laptop it doesnt seem to run as the loaner and mine is a dual core centrino.
Being playing with it at gigs for the last 3 weeks and its rock solid for audio use anyways, scratching/effects/analysing... I dont even have most of the tracks analysed. Havent tested it with videos yet. I've got an 8hr gig coming up so that will be a real test.
AMD Turion
2gb Ram
geposted Mon 26 Nov 07 @ 3:08 am
Core 2 Duo (T7300)
2048 ddr2 667Mhz
320GB sata 5400
750GB usb external
Nvidia 8600m GS 256MB
Vista
USB Maya44
DAC3
Audio only!
VDJ 5.5 = DISASTER DISASTER DISASTER.
errors on closing, database issue, and codecs dissapearing.
2048 ddr2 667Mhz
320GB sata 5400
750GB usb external
Vista
USB Maya44
DAC3
Audio only!
geposted Mon 26 Nov 07 @ 4:46 am
I only use VDJ for VIDEO. 3 residencies a week, plus special events.
Laptop
Macbook Pro 17"
2.33 ghz dual Intel
3 gb Ram
ATI X1600 256 dedicated graphics
OS X 10.5 (Leopard) running Bootcamp and Windows XP strictly for VDJ
Stability
As briefly mentioned above I run VDJ in Windows XP via Bootcamp and OS X 10.5 (Leopard). I do not run VDJ Mac. I have never had a live crash. NEVER. I am currently using Virtual Vinyl 5 rev 5 as I like the way the skin fits on my Laptop. I do all video sets anywhere from 1 hour to 6 hours at a time (3+ times a week). The only problems I run into are specific Virtual Folder crashes and Timecode instability.
Performance Ratings
Laptop - 5
My Mac runs Windows faster and better than any PC Laptop I have ever used. Plus I use OS X for everything else beside VDJ making my Windows partition clean with no processes, viruses, internet...ect.
VDJ - 4/4.5
I'm still having a few issues with the program itself. Organization with the Virtual Folders and some Timecode issues. With a better BPM engine and those issues fixed i would easily rate VDJ a 5.
Laptop
Macbook Pro 17"
2.33 ghz dual Intel
3 gb Ram
Stability
Performance Ratings
Laptop - 5
VDJ - 4/4.5
geposted Mon 26 Nov 07 @ 4:43 pm
Well since Rev 6 I can only report continued stability.
geposted Mon 24 Dec 07 @ 9:54 pm
(Dual core+ 1 Gig RAM + 100 G Memory)Me & Rev 6 = Flawless....rating 4.75/5
Running both Audio & Video using timecodes..vinyl & cd...Thank you Atomix!
geposted Mon 24 Dec 07 @ 10:32 pm
hp laptop amd turion 64 2 gig ram XP media center edition
Ati radeon express 200 graphics card 128 mb
i do mixed audio and video , strip clubs and mobile ......VDJ 5.0 rev 6 ..... has been very stable, best rendition yet going back to 4.0 ......
geposted Mon 24 Dec 07 @ 11:02 pm
Laptop
Asus A8JS
Intel Core2 T5600 1.83GHz
2GB RAM
100GB HDD
NVIDIA GeForce Go 7700 512MB Dedicated
Dedicated partition with tweaked Win XP Pro just for VDJ
External 750GB HDD for gigs (more than 3TB of Video & Audio backups @ home)
Maya 44USB
Numark Total Control
Sometimes with TimeCode Vinyls or CDs
Stability (Version 4.3)
I do 3 regular gigs per week(thur~sat)
min. 6 hours up to 8 hours (1st half automix 2nd half manual). NO breaks in between
parties & events once in a while
Very stable, no crashes or hangs for the last 11 months
haven't been playing with V5 so much, but never had a problem with it, too
still need the 2 decks automix sometimes
before my asus i had sony
i've been doing audio with it for a couple years never had a single problem
started video with it, but the video card was too weak
had to buy a new one
Asus A8JS
2GB RAM
100GB HDD
Maya 44USB
geposted Tue 25 Dec 07 @ 2:50 am
