If you go to edit BPM of a track, the X2 / /2 buttons no longer seem to work...
Sorry if this has been spotted before.
Not a major problem, but it quite useful for when the auto bpm gets its knickers in a twist.
geposted Sat 13 Nov 04 @ 12:52 am
Deluded,
They do work. I found that when you use them, most of the time the BPM won't update on the Edit BPM window although it HAS changed). It will only update after you click on another track. Then you will see the bpm number update on the track you changed before.
Weird, cause sometimes it does update instantly. It is a bug, but not a major one to me as long as it DOES change the bpm.
Hope this helped.
Killabee44
Hope this helped.
Killabee44
geposted Sat 13 Nov 04 @ 2:38 am
What I meant is that the little dialog window that pops up doesn't change, so I don't think it is updating the ones in the main window - not certain since I worked it out in my head and entered it manually which did the trick.
geposted Sat 13 Nov 04 @ 11:28 pm
