I would like it that i can use the match bmp feature on my xponent, but then for the pitch fader to work relative to its last position.
sometimes the match bpm isnt 100% right, so it would be nice to use the fader to correct it, but the way it works not you need to manually find the right position of fader.
I would like it that where ever the fader is, that it gets locked to the current pitch in vdj when the auto bpm is used. maybe allow the pitch range to be set at +-34 and the fader set to +-12. that would be really cool.
geposted Mon 26 Nov 07 @ 9:24 pm
