I am getting ready to have my first Turntable set-up I plan on using Virtual DJ running with 2 Numark TT-200 and a Behringer VMX-200 mixer. What else do I need to get it to work and how do I set it up. I am thinking you use a Y-cable from your sound card to RCA for the tables and the time encoded records. What else do do I need to do?
Thanks
-Drew
Thanks
-Drew
geposted Tue 27 Nov 07 @ 6:54 am
firstly you will need a soundcard with at least 2 inputs and 2 outputs - e.g. maya44 or u46dj, hercules mk2 etc. a y cable wont work.
secondly u will need a pro version or register
http://www.virtualdj.com/purchase/
have a look at this manual
http://www.virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf
hope this helps and look forward to seeing you as a registered user
geposted Tue 27 Nov 07 @ 8:18 am
