Just upraded to new version and i love how i no longer have problem with automix and how it use to "skip" to middle of song when loading the next one. However i noticed when i would maually load a playlist song by song, If i switched folders to search for songs the playlist would disapear. Is this something that i need to check or uncheck in config. Also when playing a playlist the songs stay in list and the program works it's way down through the folder with the songs staying in the list (above what is playing). is there a way to make them go away after the song plays?
Thanks and i only use automix when doing a happy hour/dinner set. :)
geposted Wed 28 Nov 07 @ 2:51 pm
Anybody?
geposted Wed 28 Nov 07 @ 6:01 pm
Go to config>options and set "Autoload Playlists" to <disabled>, that ought to keep your list from vanishing as you navigate. Regarding the songs not being removed from the list as they are played, this is by design. There is an option called "remove played" on the management menu of the playlist, however. You can find more info. on page 17 and 18 of the manual. God luck ;)
geposted Thu 29 Nov 07 @ 8:22 am
i leave the trax in on purpose so i can go back and add them to virtual folders , or edit tags ......
the automix is a great feature , if you are a mobile guy or do strip clubs , it's very handy ..... it doesn't diminish you as a dj ........
so far , no one has ever said " oh wow you sure can load a track " .......... the auto load frees up yer hands for coppin' a quick uuuuhhhh coffee ...
geposted Thu 29 Nov 07 @ 8:38 am
I also work at a strip club. It you leave the songs in the playlist that are played, this is a good way to save your playlist when you are done for later reference. Otherwise you can hit the + sign under the automix button on the playlist and hit the remove played option.
DJ Jimmy J
www.SubZerosounds.com
DJ Jimmy J
geposted Fri 30 Nov 07 @ 3:54 pm
No zgadzam sie ta nowa wersja jest super :D jezeli o niej mowa xDDD bo nie czaje hehe pozdro DJ ReJT
geposted Fri 30 Nov 07 @ 5:34 pm
yo
I have the same problem ,to sort that out everytime you change folder make sure your auto mix is on & u wont lose your song list
Cheers Musicmatch
Cheers Musicmatch
geposted Sun 02 Dec 07 @ 9:21 am
