im trying to create a mix but the headphone cues dont work or arent available wtf? for instance i have a song playing on one deck and then when i try to cue a song on the other while recording i cant hear the music unless i bring thecross fadesback into themiddle and it messes up the mix what should i do?
is there aspecific skin i should use, if your still confusedon what imtalking about whenyour using table top turntables and you want to find you cue points you hit the headphone cue and set the level to the left side or right side.....
geposted Wed 28 Nov 07 @ 8:34 pm
what version are you using?
what soundcard do you have
you need a 4.1 or greater soundcard to use headphone preview
geposted Wed 28 Nov 07 @ 8:39 pm
ill check
geposted Wed 28 Nov 07 @ 8:47 pm
sigma tel high definition codec 6.10.5405.0
version
widows vista
operating system
version
widows vista
operating system
geposted Wed 28 Nov 07 @ 8:58 pm
on the normal skin where is the headphone cue at?
geposted Wed 28 Nov 07 @ 9:02 pm
Hi
By chance are you using fader start ? If you are you will have to deactivate to cue in your headphones
Hope that works i had the exact same problem
Keep spinning
DJ MikeD
Keep spinning
DJ MikeD
geposted Wed 28 Nov 07 @ 9:19 pm
as a matter of fact i think i am using it thanks!!!!!!!!!!
geposted Wed 28 Nov 07 @ 9:23 pm
oh crap i forgot to adjust the headphones in the(settings) outputs
geposted Wed 28 Nov 07 @ 10:19 pm
