This problem started last weekend. I have been using v5.5 since it was released.
After loading songs into the playlist (on the right) if I click on a new virtual folder the enire playlist disappears. This does not happen if autoplay is on.
What could cause this?
geposted Thu 29 Nov 07 @ 1:03 am
Take a look in the configuration.
Theres a tab where you can setup BPM-scanning, Fading, etc.
There is also a point to choose where the Playlist is shown: Only in the middle, smart etc.
I had the same problem and playing around with this setting solved this for me.
Happy mixing whatever your software is called
Tanzi
Tanzi
geposted Thu 29 Nov 07 @ 2:04 am
Thanks.
I went to Opions/Autoload Playlists=Disabled and no longer have the problem.
Not sure what that function does but it worked.
geposted Thu 29 Nov 07 @ 2:09 am
I dont know what these settings do neither.
Maybe someone can give us an explanation of these functions?
Tanzi
Tanzi
geposted Thu 29 Nov 07 @ 7:41 am
