Here's an idea: what do you think of adding fader start on the hercules dj console? this feature does not exist in VDJ, I am proposing it be added...
What is fader start? Fader start is a link between the mixer and the the audio deck. here is how it works...
Turn ON the faderstart switches for both decks.
If you want to use the fader start with the crossfader, assign that channel to the crossfader.
Load a track each deck, cue them up
Move the fader (or crossfader) on the Hercules from the zero point and the track will start (if you assigned 1 & 2 to the XF, when you're on the 2 side and move towards 1, 1 will start).
If you move the fader back to the zero point, it will stop and return to your cuepoint. Move it away again and it will start again.
You need to try this on a real CD deck to get the idea what I am talking about
geposted Sun 14 Nov 04 @ 2:53 pm
