Looking for a ready built laptop that can do the following out of the box.
run Virtual DJ with karaoke
run virtual DJ with karaoke & video
please offer suggestion for each of the two above.
Does such a laptop exist that can do the above right out of the box?
thanks
thanks
geposted Fri 30 Nov 07 @ 2:13 pm
Hi spam4us
It is 3.35 am UK time. Looking at the time you posted this i would had thought you had received a reply. The answer is no. Alot is dependent on OS and setup. You can go for the max spec recommended and still have problems. The VDJ team are aware of such and in time address these accordingly with fixes. However most Laptops out of the box are sold with Vista which is in my opinion should be an installation of choice as it causes to many conflicts than it resolves. VDJ give the max spec required for their product and with adjustments to Vista it works well . You need to aim for a high spec machine " found on other pages of the site " its worth the cash in the long term . I would advise you to by a machine with out a OS installed.
Chris
Chris
geposted Fri 30 Nov 07 @ 10:00 pm
