OK, I am about to lose my mind. I have a bunch of video DVDs that I ordered from Promo only, how the hell do I rip them into my computer. We all know Virtual DJ ripper sucks, I tried smart ripper and could not get it to work right. I tried magic ripper and that gave me video, but no audio. I tried AVS tools and I can't get that to seperate the videos, and it takes forever for 1 DVD. Any suggestions would be great, or some detailed how to with a certain program. I am using windows XP. Thanks....
geposted Mon 03 Dec 07 @ 3:40 pm
Use Smartripper, it works fine for the 5,000 .vobs that I have ripped. Do a search for a link. It's free, also.
geposted Mon 03 Dec 07 @ 3:55 pm
What are the settings you use, I did it and it stopped half way through the DVD.
geposted Mon 03 Dec 07 @ 3:57 pm
or you can look on tophouse' s blog
http://www.virtualdj.com/blog/TopHouse/
this is how I do mine as many others have.
geposted Mon 03 Dec 07 @ 4:08 pm
You do know you can only rip a chapter at a time? What I mean is it's not like a cd, where you can name all the tracks, and then rip the whole DVD.
Movie
Key-Check=Don't decrypt
File-Splitting=Maxfilesize (so you can ripp two or more chapters together, like the 3 song mixes), otherwise every chapter
Options= Unlock drive,DeMacrovision, Fast error skip
VOB file access=auto
Movie
jimspinnin
i use avs all the time, i can name and rip a track in under a minute are you using avs remaker, if not thats the one you should use not the other two programmes that comes with the bundle, if you want i'll do a blog on it or pm me...
Tayla
Tayla
geposted Mon 03 Dec 07 @ 6:03 pm
I got dvd encrypter to work from tophouse's blog, Thanks. but I just dont understand why some tracks just dont want to rip? The dvds are brand new....
geposted Tue 04 Dec 07 @ 3:01 am
I have one store baught dvd compulation that refuse to rip no matter how I try to split it.
geposted Tue 04 Dec 07 @ 11:39 am
yo fatkatz how ya doin
look on topics page for "are you having problems ripping" might help...
Tayla
Tayla
geposted Tue 04 Dec 07 @ 11:56 am
OK, I can finally get the VOB's off of the DVDs with no problem, but what about a program to convert my current VOB's to AVI or others. I need one that you can load multiple VOB's and then just let it sit. I dont want to have to do 1 at a time. Thanks for the help so far.
geposted Wed 05 Dec 07 @ 4:51 pm
top house also has that in his blog
geposted Thu 06 Dec 07 @ 1:41 pm
Jim why do you want to convert to AVI, just rename the VOB as Mpeg and u are good to go.
geposted Thu 06 Dec 07 @ 2:37 pm
Help me out. What is the benefit of doing this?
geposted Thu 06 Dec 07 @ 2:51 pm
Can you do that? I dont want vobs due tp their size. I dvd that was 7.some gig in now 1.some gig as an avi file. This is one of the few extensions I found to work in Virtual DJ untill rev 6 came out, now my mp4s work.
geposted Thu 06 Dec 07 @ 3:06 pm
Hi, I use DVD Shrink to rip a DVD.
It is possible to select/split the clips etx and is very fast.
Then I convert them into divx - gives me a small file size, fast loading in VDJ, and very acceptable quality
Johans
Johans
geposted Sat 08 Dec 07 @ 12:38 pm
