hi, when i press ALT+1 or 2 or 3 (The cue points) my laptop makes this a single beeping noise every time i press this combination. It's really weird because sometimes it would stop and then it would do it again. When i dj my gigs, i really dont want to hear it because it ruins everything. So do you think it's a software or my laptop? How can i fix it? thanx a lot
- dj krazie e
- dj krazie e
geposted Mon 03 Dec 07 @ 8:23 pm
have you tried reseting the cue point to recognize a different set of keystroke... I did this due to fact that many of the default shortkeys i'm not going to use so reprogrammed it what I would use.
geposted Tue 04 Dec 07 @ 11:45 am
Check Your audiosettings in Windows. There you must deactivate the Windows sounds !
geposted Wed 05 Dec 07 @ 3:32 am
