Forum: Wishes and new features
Topic: Anchors A-Weigh
Is there a way to give us drag control over the anchor placement?
It takes forever to move them with the buttons.
geposted Mon 15 Nov 04 @ 12:19 am
Just drag the waveform until the point you want to place the anchor on is under the green middle line, and press "set anchor" in the bpm window. It's that simple.
I dont see "set anchor" in the bpm window. I only see "set beat".
Am I missing something here?
I drag the wave form so the 1st down beat is under the "red" (cdj 700) center line, but I can't move the anchors in any way except with the or in the top left corner.
do just what you are doing, then hit the set anchor button (1-6). if you want to re-set it, just stop the wave form, drag it to where you want it and hit the set ancor point wou wish to tag there. Very simple...and much more accurate that a draggable anchor.
"then hit the set anchor button (1-6)"
What the heck are you talking about?...!
What "anchor button"?
edit bpm on a "loaded" track, perhaps !
(set beat = set anchor, ok?)
