Hello all, just curious if there is such a feature. What I'm looking for is a way to tempoarily lock the pitch sliders together, so they track each other? Used to be able to do this in pcdj fx, can't try this now as I no longer have this program installed (I shall not say why!).
This was one handy feature though, as you could speed up, or slow down both decks simultaneously, using only one pitch slider.
Any ideas folks?
best regards, Dave
Any ideas folks?
best regards, Dave
geposted Tue 04 Dec 07 @ 8:51 pm
This is still a feature and you can even shortcut it to keyboard or midi.
geposted Wed 05 Dec 07 @ 4:20 pm
Many thanks fatkatzdj. So how do I enable it?
geposted Wed 05 Dec 07 @ 8:18 pm
Select the turntable that you want to automatically slide, and make it the selected deck (I.e. highlighted).
Press 'B' on your keyboard and the Sync buttun should light up and stay on.
Goto your other deck and move the slider. The deck with the locked Sync button will automatically move, keeping in Sync with the deck you are manipulating.
Once finished, press the 'B' key again to disable the lock, and continue playing.
Hope this helps,
Steve.
Hope this helps,
Steve.
geposted Thu 06 Dec 07 @ 3:58 pm
Many thanks Steve, I,m gonna give this a try right now...
geposted Thu 06 Dec 07 @ 9:41 pm
