And again... do any of you handy folks know if it's possible to have the clipbank visulisations, sequence automatically, or even randomly. This would be very handy. At the moment I can get only one slot to run. For the next one to appear I have to click the clipbank box.
I may be being thick here!?
Best regards, Dave
Best regards, Dave
geposted Tue 04 Dec 07 @ 8:55 pm
chaffer
your not, this has been asked about a lot by many including myself in the past, luckily there is another update thats being mooted about to come out soon hopefully as usual the dev team will incorporate it in that, as they normally pick up on users requests, if not then in the next version because it would ecnchance the clipbank effects,
in the meantime why not extend your clipbanks with different effects some of the guys including myself have already done this if you don't know how check out my blog for some ideas or one or two of the others...
Tayla
Tayla
geposted Tue 04 Dec 07 @ 9:21 pm
I've just this minute written a small plugin that can change the current clipbank clip randomly. Unfortunately there is a big problem with it - there is no way of knowing if a clip has played once, is still playing, is at a loop break etc... it will only shift on a time interval. If your clips are all good loops (even better if of a similar length) then it's not too much of an issue though :)
The only other oddity is that it has to be activated before clipbank, but thats not much of an issue either.
Hopefully VDJ will fix this natively as this is more of a kludge than anything else ;)
geposted Thu 06 Dec 07 @ 12:44 am
You've done more than I could do, but I think I will wait for the real thing.
geposted Thu 06 Dec 07 @ 1:01 am
Well this is good, thanks for your replies and help as always, it's very much appreciated.
And SBDJ, keep it up, sounds like you're doing good work there. Hope your plugin will appear in the downloads section at some point.
Do we all think a bigger clipbank, perhaps scrollable would be good also?
geposted Thu 06 Dec 07 @ 9:38 pm
To be honest, I've not uploaded it yet. Needs a proper test, so I might try it out this weekend. As I say, it's not a real solution, but could be used as a temporary stopgap if anyone is interested?
geposted Fri 07 Dec 07 @ 9:59 am
sb
well get your finger out we are all dying to use this...lol
thanks
Tayla
thanks
Tayla
geposted Fri 07 Dec 07 @ 10:57 am
