Hello I have just purchased virtual dj and have ordered a Maya 44 USB sound card, and some timecoded vinyls, first are the Numark timecodes ok to use with virtual dj? as you were out of stock and therefore I couldn't buy yours. Secondly, do I have enough to use the program properly with:
2 turntables - Numark TT1625
Mixer - Numark DXM09
Speakers, obviously
Maya 44 USB external sound card
Timecoded vinyls
and of course, Virtual DJ.
I have also set up another monitor over my turntables therefore got a new graphics card for dual monitors in the studio.
And, I go a mouse for using near turntables monitor!.
Speakers, obviously
Timecoded vinyls
geposted Wed 05 Dec 07 @ 2:58 am
yes numark TCV work fine ,
that should be ok but what is your pc spec?
geposted Wed 05 Dec 07 @ 7:51 am
Also if you modify your profile and put your serial number in you can download the skins and pluggins.
Jimmy b
geposted Wed 05 Dec 07 @ 8:57 am
