Hi!
Got VDJ a week ago, I'm using TCCDs on different CD-players and everything works OK in Smart mode - the pitch slider follows the CD-players' signal perfectly. The only problem is the cue point moving back and forth when coming back to it after listening to the track for a while.
I then tried the absolute mode: it fixes the problem and the cue point remains solidly in place, but the software now thinks that the pitch is set to +2.1%, when the CDJ100 shows 0.0. Has anyone had this kind of problem?
I'm thinking it has something to do with the way the time control file was burned, does anyone know the optimal way of burning it? I use the "PRO"-file, the other one is just too loud.
Thanks in advance.
Thanks in advance.
geposted Wed 05 Dec 07 @ 12:12 pm
