Hi!.
I wonder if i could use a dj console to mix between two xp10´s.
so the xp10 1 is deck one on vdj and xp10 2 is deck 2 on vdj and the dj console operates the crossfader etc.
And if it works does it works good or bad Fast or slow...
Thank u for ur answers.
geposted Mon 15 Nov 04 @ 1:00 pm
this will work fine
geposted Mon 15 Nov 04 @ 4:22 pm
ok thx.
Then i´m about to buy two of them : )
geposted Mon 15 Nov 04 @ 5:42 pm
i would like to know if you tried it DJ IN NORWAY and with wich pc system ?
ii tried it with my laptop and it doesn't work together
if you activate both xp10's + djconsole
the jogwheels go funny and you can even see on the screen that VDJ does not work like it does without these three controllers.
the sound goes really funny also
maybe with more than 512 mb ddr-ram it works better but i don't think so
somebody else got different experience ????
(wireless dj have you tried this also)
ivar
ivar
geposted Tue 16 Nov 04 @ 2:49 pm
after doing some more tests
it is possible, but don't use a powered hub that is why it didn't work well for me in the beginning (but VDJ is a bit slower than normal)
but the xp 10's sound quality is so much better then the sound quality from the console
so instead of using the console i would buy another external mixer
ivar
ivar
geposted Wed 17 Nov 04 @ 6:15 pm
