Hi Everyone!
Is there any way I could assign the effects to a keyboard shortcut?
DJ Willymix
DJ Willymix
geposted Mon 15 Nov 04 @ 8:09 pm
Most of the effects are now keyed to F1-F12 already.
If you go into Set/Keyboard you can modify any setting you want.
geposted Mon 15 Nov 04 @ 8:18 pm
is the samples that are set to F1-F12 by default, to create one for an effect, goto the keyboard shortcuts menu.
click create, then find the label effects. create a shortcut for each of the decks and effects.
for example
num1, effect (value 1), desk 1, momenterily
and so on
i use num pad 1-6 for the effects 1-3 for left deck 4-6 for right deck
for example
and so on
geposted Mon 15 Nov 04 @ 8:43 pm
Ok, I have just resently had to get a full re-install of 2.06 and I now have no keyboard shortcuts. every other version had preset keyboard shortcuts! how do I create my own? I see this message that says " check our website blah blah?" what is up!
geposted Wed 15 Dec 04 @ 1:35 am
