I'm using 2 turtle beach sound cards, and for some reason I can only get 1 deck to play, for what I understand both decks should be able to play under one mixer channel isn't that correct?
what could I be doing wrong?
geposted Fri 07 Dec 07 @ 4:16 pm
You have to go sound setup in config and select two line mixer. Next, in the drop down window below that select 2 cards. Finally, In the drop down window below that look for your cards and in each slot designate one card.
geposted Fri 07 Dec 07 @ 4:35 pm
