hello
it happened twice:
while i was mixing, a box(little window) appeared telling me: virtual dj has found an error: click on RECOVER or SHUTDOWN buttons
(i dont remember the exact words but they were like the above one.)
why does this happen? how can i understand what the cause is?
please help! i had to interrupt my mix :(
thanks
it happened twice:
thanks
geposted Sun 09 Dec 07 @ 7:54 am
It's because something is critically wrong with your setup and VirtualDJ needed to shutdown. If you are using the demo, you should not be trying to use it for 'real' events, it's only a demo so you can see what the program is able to do. If you are using a crack then you should not expect the software to run with out problems. If you like the features of the program, please visit the purchase site and buy a license.
http://www.virtualdj.com/purchase/
geposted Sun 09 Dec 07 @ 9:39 am
