Help
I have a Audio Advantage Roadie sound card that will not work on Vista. They have a patch that will enable it to work but the problen is I cannot remove the old program and drivers to make it work. I have tried unistall from control panel and I have tried removing it from my programs. Any advice would be nice
geposted Sun 09 Dec 07 @ 7:49 pm
Use a 9mm, and it will be removed. The other drivers will take note, and not give you any more trouble, and uninstall when you ask them to. On a serious note, are you sure you have to uninstall the drivers? Maybe the patch installs over the driver. If that fails, you may have to reinstall the OS.
geposted Sun 09 Dec 07 @ 8:31 pm
Just a shot in the dark,( no pun intended) but have you thought of looking and removing it from the windows registry. Might work.
Jimmy b
Jimmy b
geposted Sun 09 Dec 07 @ 8:32 pm
