Everytime roughly around the 10min mark both timecoded vinyl loses single and i am unable to control the songs. Im using serato timecode i dont know if that could be causing the problem as im unable to get vdj ones here in newzealand. But ive seen funkturnal sucessfully used serato timecode with vdj?
Is there any settings i can do to help improve what i have?
Settings
Performance set all the way to the left
safe mode and overclock - ticked
Speed - 33rpm
Mode - Smart
Antiskip - ticked
hardware
2 technics 1210m5g
M audio conectiv
Vestax mixer.
Using lastest vdj 5.r6
Thx
Settings
Speed - 33rpm
Mode - Smart
Antiskip - ticked
hardware
2 technics 1210m5g
M audio conectiv
Vestax mixer.
Thx
geposted Tue 11 Dec 07 @ 1:19 pm
I think that's where your problem is, the serato timecode. they are not support yet, maybe soon.
Have you tried to find a Numark agent in New Zealand, If you can the numark timecoded vinyl works, there the same as ours and 3rd gen.
Jimmy b
Jimmy b
geposted Tue 11 Dec 07 @ 1:56 pm
Dj Alki, I think once the SSL plug in is complete, this issue will be resolved.
geposted Tue 11 Dec 07 @ 2:23 pm
Or he could get some VDJ vinyls shipped to him. I don't get the hold up. I can get anything shipped overnight, why is it taking so long to get these to New Zealand?
geposted Tue 11 Dec 07 @ 2:52 pm
This will solve your problem. Go into the registry(Start - run - type "regedit"
Go to hkey current user
software
virtual dj
now scroll down until use see timecodepos1 and timecodepos2
Chaange both of these values to 9999999
This should sort you out
software
virtual dj
geposted Tue 11 Dec 07 @ 3:12 pm
software
virtual dj
software
virtual dj
That should work. I'm the one who initiated this work around but it's not really a resolution.
geposted Tue 11 Dec 07 @ 3:43 pm
^^ see I tell the truth:P
The best wya until the ssl time code support comes out
geposted Tue 11 Dec 07 @ 3:49 pm
thx guys ill definately try it tonight when i get back home :) Cant wait.
geposted Tue 11 Dec 07 @ 4:05 pm
