Hi my peeps,
I need help getting a external Sound Card for my laptop (Windows Vista)that I can use to cue songs. Laptop only no CDs or Serrato. Thanks a link would be helpful as well.
Sean
Sean
geposted Tue 11 Dec 07 @ 8:16 pm
If you want cheap, you can try something from m-audio: http://www.m-audio.com/
Personally I prefer to stay away from Firewire and USB and opt for something like this:
http://www.emu.com/products/product.asp?product=13554
But first you need to check if your laptop uses CardBus or ExpressCard (same thing, but newer version and NOT backward compatible).
geposted Wed 12 Dec 07 @ 1:47 am
If your computer has an expresscard 54 slot, you can use the Creative X-fi card:
http://us.creative.com/products/product.asp?category=209&subcategory=669&product=16642
It's what I've been using for the last few months. It's very simple compared to a lot of the other things people will be telling you about on this forum, but if you're looking for something that just plain works, this is it! Also, it has Vista drivers including x64!
geposted Wed 12 Dec 07 @ 3:04 am
A good solution for u is numarks djio wich is designed for virtual dj and numark cue check here:
http://www.numark.com/djio
and for a first look in the market just for the price look here:
http://www.thomann.de/gr/numark_dj_io_audio_interface.htm
geposted Wed 12 Dec 07 @ 3:07 am
