Hello.
I push the button of the sampler.
A sample stops when I push the button once again before a sample is finished.
change this setting?
When it overwhelms a button once again that I hope before a sample is finished, a sample does not stop, and it wants to be regenerated from the beginning of the sample.
I want you to cope by future version up now if I cannot set it under the present conditions.
Thank you.
Thank you.
geposted Wed 12 Dec 07 @ 3:22 am
The sample you are playing is set to "loop" mode. Click the little round target under where it says loop or jingle to open the menu and uncheck the "loop" setting. Then, when you play the sample, it will stop by itself without having to click the button again ;)
geposted Fri 14 Dec 07 @ 3:33 am
Thank you for an answer.
But the way of my question seems to have been bad.
Is there the setting to begin at the beginning of the sample again when I push the button once again before a sample finishes being over?
The setting of TROQ comes to look like it when I put up an example.
Thank you.
Thank you.
geposted Tue 18 Dec 07 @ 2:11 am
